The is a curves update for QuadTone RIP users of the Piezography MPS Glossy system.
Piezography Glossy printing is any type of printing on non-matte papers (including Baryta).
These papers require our MPS inks which are both matte and glossy compatible due to additional layers of pigment encapsulation. All Piezography pigment is encapsulated to prevent agglomeration due to static charge. However, in order to adhere to non-matte surfaces, we developed two new inks (Selenium K7/K6 and Warm Neutral K7/K6) and a new photo black shade 1 (MPS Black: aka Selenium Shade 1), and a Gloss Optimizer that is used to overcoat.
The process of making a Glossy Piezography print is to select the correct ink curve for the non-matte medium, a quick dry, and then a second printing of Gloss Overprint using the GO curve. You do not print the same image over itself. Instead you make a small white image in which the entire canvas is white (RGB 255,255,255). There should be no pixels that are not pure white. The GO only prints when it detects a pixel value of RGB 255,255,255. Because the paper margins are considered to be white by QTR, the use of a small white image and the GO curves causes QTR to overprint the entire sheet with a precise amount of Piezography Gloss Overprint up to the limits of the QTR RIP margins which are 1/8″ top and sides and .52″ from the bottom. The effect is perfect when compared side-by-side with either an EPSON ABW or an HP print. All of the gloss differential is perfectly equalized so it is not possible to discern the difference between ink and paper. Bronzing is minimalized and with some papers completely eliminated. There is no metamerism.
Eventually these Glossy curves will be part of the QTR download. Until then you can download and install yourself. If you need a curve for a paper that is not listed you can have a custom curve made by InkjetMall for $99 by clicking here.
Instructions for installing curves
NOTE: With Mac users, you must uninstall your Quad printer model then reinstall it using the install.command located in the same folder you placed the new curve in. This will show the new curve in QuadTone RIP.
Select your printer below and click on the download button.
Epson 2200: Epson Exhibition Fiber, JonCone Studio Type5, GO only
Epson 2200 Glossy curves
Epson 3800-3880: Epson Exhibition Fiber, Epson Lustre, FotoSpeed Platinum Gloss, Hahnemuhle Baryta FB, Hahnemuhle PhotoRag Baryta, Harmon Gloss Baryta Warm, Harman Glass FB Al, Ilford Gold Fiber Silk, Ilford Smooth Gloss, JonCone Studio Type5, GO only
Epson 3800-3880 Glossy curves
Epson 4000: Canson Baryta Photo, Epson Exhibition Fiber, Red River Pearl Metallic, JonCone Studio Type5, GO only
Epson 4000 Glossy curves
Epson 4800: Hahnemuhle Fine Art Baryta, Hahnemuhle Photo Pearl, Hahnemuhle Photo Rag Pearl, JonCone Studio Type5, GO only
Epson 4800 Glossy curves
Epson 4880: Canson Baryta Satin, Canson Infinity Baryta, Epson Exhibition Fiber, Hahnemuhle Photo Rag Baryta, Harman Glossy Fiber White, InkPress Baryta White, JonCone Studio Type5, GO only
Epson 4880 Glossy curves
Epson 7600-9600: Canson Baryta Photo, Epson Exhibition Fiber, Red River Pearl Metallic, JonCone Studio Type5, GO only
Epson 7600-9600 Glossy curves
Epson 7800-9800: Hahnemuhle Fine Art Baryta, Hahnemuhle Photo Pearl, Hahnemuhle Photo Rag Pearl, JonCone Studio Type5, GO only
Epson 7800-9800 Glossy curves
Epson 7880-9880: Canson Baryta Satin, Canson Infinity Baryta, Epson Exhibition Fiber, Hahnemuhle Photo Rag Baryta, Harman Glossy Fiber White, InkPress Baryta White, JonCone Studio Type5, GO only
Epson 7880-9880 Glossy curves
Epson R1800: Epson Exhibition Fiber, Epson Ultra Premium Lustre, Hahnemuhle Baryta, Ilford Gold Fiber Silk, JonCone Studio Type5, GO only
Epson R1800 Glossy curves
Epson R1900: Epson Exhibition Fiber, Epson Ultra Premium Lustre, Hahnemuhle Baryta, Ilford Gold Fiber Silk, JonCone Studio Type5, GO only
Epson R1900 Glossy curves
Epson R2400: Epson Exhibition Fiber, JonCone Studio Type5, GO only
Epson R2400 Glossy curves
Epson R3000 and Epson R2880 (both printer models use these curves): Epson Exhibition Fiber, JonCone Studio Type5, GO only
Epson R2880 and R3000 Glossy curves
Epson 4900 7900 9900 : Canson Baryta Infinity Photographique, Canson Baryta Satin, Epson Exhibition Fiber, Hahnemuhle Photo Rag Baryta, Harmon Photo Baryta FB Warm, InkPress Baryta WarmTone, JonCone Studio Type5, GO only
Epson 4900 7900 9900 Glossy curves
The GO curve for the Epson 2200. Which cartridge position is used for the Gloss optimizer?
Is it correct to assume that shade 1 is replaced with an GO-Cartridge?
I’ve so far used hahnemühle fineart protective spray, the results are great, but it’s not as convenient as printing…:-)
